CraigC Posted April 30, 2019 Share Posted April 30, 2019 Can anyone tell me why the linework in this elevation (screenshot from a sheet layer) is so fuzzy? The section and the floorplan are not fuzzy. Quote Link to comment
Guest Wes Gardner Posted May 1, 2019 Share Posted May 1, 2019 I assume you made the elevation with the "Create Section Viewport" command (or the Clip Cube)? You can also bump the sheet layer's DPI up if you need to...usually the default is OK for line work. Quote Link to comment
TomKen Posted May 1, 2019 Share Posted May 1, 2019 Is your viewport render mode set to Open GL? Quote Link to comment
CraigC Posted May 1, 2019 Author Share Posted May 1, 2019 17 minutes ago, TomKen said: Is your viewport render mode set to Open GL? Yes. Quote Link to comment
Guest Wes Gardner Posted May 1, 2019 Share Posted May 1, 2019 Typically, for views like sections and elevations, you should set the render mode to Hidden Line Quote Link to comment
Guest Wes Gardner Posted May 1, 2019 Share Posted May 1, 2019 You +CAN+ use other render styles like you've done but you WILL have to increase the sheet layer's DPI settings... Quote Link to comment
TomKen Posted May 1, 2019 Share Posted May 1, 2019 Set the background render to OpenGL, under background render setting set uncheck draw lines. Set the foreground render to hidden line. Increasing the DPI on the sheet will improve the line work as well. Quote Link to comment
