LarryAZ Posted February 21, 2005 Share Posted February 21, 2005 I'm still learning new things every day I use VW. With the intelligence built into VW I don't see any reason to have a snap grid set. As soon as you rotate any item it is off the grid anyway. What I want to know is there some other reason I want to keep the snap grid to 1" or some minimum number? Do I compromise my date by not having a grid? Thanks again for the help. Quote Link to comment
Travis Posted February 21, 2005 Share Posted February 21, 2005 Larry, You only compromise your data if it's inaccurate. The snap grid is useful to help you stay accurate. Personally, I don't use it at the large scale, but rather at the small end. Mine's set to 1/8". Good luck, Quote Link to comment
LarryAZ Posted February 23, 2005 Author Share Posted February 23, 2005 I just made a great discovery that I guess everyone else must know. I was thinking that the snap grid was only useful if you are working horizontal and vertical. The most useful part of the grid is when you have to work on a plan that is on an angle. It is the only way to make the dimension work correctly. So I've completely changed my mind. The grid is extremely useful. Duh... Quote Link to comment
