Sam Lee Posted January 7, 2019 Share Posted January 7, 2019 Ive recently changed from using VWX 2014 to VWX 2017 (both Architect) I use the File > Publish command to batch export PDFs. In 2014 each time i use the File > Publish command it gave me an option of my sheet layers on the left hand side and i could move the ones i wanted over to the right hand side. But in 2017 it seems to auto populate the right hand side of the page with the files i published in the last publish run. Any ideas why this is and how i can get it to behave like it did in 2014 ? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted January 8, 2019 Vectorworks, Inc Employee Share Posted January 8, 2019 Hi Sam I think this is intended as a time-saving aid, as many will be publishing the same set over and over again. There isn't a way to restore the 2014 functionality as such (that I am aware of), but you could explore using Saved Sets of different collections of sheets, which you can then rapidly select using the Set to Publish pop-up menu at the top of the dialog. 1 Quote Link to comment
Vectorworks, Inc Employee Vasil Kitanov Posted January 8, 2019 Vectorworks, Inc Employee Share Posted January 8, 2019 Hi Sam, As Tamsin said this was made on purpose, because of Saved Sets. But you can use "<<" button as on the attached image to clear the publish list. Best regards, Vasko 2 Quote Link to comment
