Carles Olle Posted November 22, 2018 Share Posted November 22, 2018 (edited) This is a question that probably has a simple answer but that, for some reason I cannot manage to get right. So far I have this code but it does not seem to produce the expected results (the 3D poly-line does not show any texture at all): vs.BeginPoly3D() vs.Add3DPt((-5, 0, -5)) vs.Add3DPt(( 5, 0, -5)) vs.Add3DPt(( 5, 0, 5)) vs.Add3DPt((-5, 0, 5)) vs.Add3DPt((-5, 0, -5)) vs.EndPoly3D() image = vs.LNewObj() textureRef = vs.Name2Index("Test texture") vs.SetObjExpandTexture(image, 0) vs.SetTextureRef(image, textureRef, 1) vs.SetDefaultTexMap(image) vs.SetTexMapBool(image, 3, 3, True) # repeat horizontally vs.SetTexMapBool(image, 3, 4, True) # repeat vertically vs.SetTexMapInt(image, 3, 1, 0) # plane projection vs.SetTexMapReal(image, 3, 1, 0) # offset x vs.SetTexMapReal(image, 3, 2, 0) # offset y vs.SetTexMapReal(image, 3, 3, 10) # scale vs.SetTexMapReal(image, 3, 4, 0) # rotation Why this doesn't work? Any hint will be appreciated. --Carles Edited November 30, 2018 by Carles Olle Quote Link to comment
Gelde-Aart Posted November 27, 2018 Share Posted November 27, 2018 To assign a texture to the 3D object use the vs.SetTextureRefN(obj, textureRef, texPartID, texLayerID), so your script would look like: vs.BeginPoly3D() vs.Add3DPt((-5, 0, -5)) vs.Add3DPt(( 5, 0, -5)) vs.Add3DPt(( 5, 0, 5)) vs.Add3DPt((-5, 0, 5)) vs.Add3DPt((-5, 0, -5)) vs.EndPoly3D() image = vs.LNewObj() textureRef = vs.Name2Index("Test texture") texPartID = 0 texLayerID = 0 vs.SetTextureRefN(image, textureRef, texPartID, texLayerID) In the above the texPartID is the primary and the texLayerID is about the base object (0) or decals(1 and further). 1 Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted November 27, 2018 Vectorworks, Inc Employee Share Posted November 27, 2018 Thanks spaghetto for helping! I think one detail is that the texture part for 3D polygons should be 3 (for overall texture part). HTH 1 Quote Link to comment
Gelde-Aart Posted November 27, 2018 Share Posted November 27, 2018 Dave your right: 3 is overall, but don't know why it also did work with the 0 as texturePart... Did a quick backwards test with an extrude and it seems that 3 is overall, 0 are the sides, 4 is the Top and 5 is the Bottom of an extrude. Quote Link to comment
Carles Olle Posted November 28, 2018 Author Share Posted November 28, 2018 That's exactly right. Thanks (I have another question but I'll open a new topic) Quote Link to comment
DomC Posted August 30, 2024 Share Posted August 30, 2024 Hi Searched the Forum but did not found another thread about the textur mapping: 1. I have attach a textur on an extrude. The Extruse can have 4 or more vertex points of a 2D Poly 2. Starting point is alsways the same and also the direction is known. Main question is, how to prevent texture mapping from aligning to the longes vertex of the face? I use as example this, to rotate, which works. Also Flipping is working vs.SetTexMapRealN(rec, 3, 0, 4, angle) I tried this but this does not change the mapping vs.SetTexMapBoolN(rec, 3, 0, 7, False) vs.SetTexMapBoolN(rec, 3, 0, 5, False) What i do now is, i get the bound in x and y (view on the face) and then rotate by 90 degrees if the y is bigger than y so texture would stay horizontal aligned to the world coordinates , which works for rectangular shapes. I now have to deside if i analyse the shape (if shape is not rectangular) for the longest edge or if there would be an existing function for that. My testing code looks like this: vs.SetDefaultTexMapN(rec, 3, 0) vs.SetTextureRefN(rec, texRef, 0, 0) # flip horizontal #vs.SetObjectVariableInt(rec, 540,1) vs.SetTexMapBoolN(rec, 3, 0, 7, False) vs.SetTexMapBoolN(rec, 3, 0, 5, False) #texture part, overall is 3. Selector: init:1, flip:2, repH:3, repV:4, long edge:5, worldZ:6, auto align:7 angle = 0 ''' if 'links' in c: if breite < h: angle = 90 * (pi / 180) else: if len(final_contour) < 5: #Rechteck angle = 180 * (pi / 180) else: angle = 180 * (pi / 180) ''' if 'rechts' in c: vs.SetTexMapBoolN(rec, 3, 0, 2, True)#flip vertical axes '''texture is aligning not to the bounds it aligns to single edges of object''' if breite < h: angle = 90 * (pi / 180) else: if len(final_contour) < 5: #Rechteck #vs.AlrtDialog(tex_name) angle = 180 * (pi / 180) else: #vs.AlrtDialog(tex_name) angle = 0 vs.SetTexMapRealN(rec, 3, 0, 4, angle) #vs.SetTexMapBoolN (rec,3,0,3,True) #vs.SetTexMapBoolN(rec, 3, 0, 2, False)#flip vertical axes #vs.SetTexMapBoolN(rec, 3, 0, 2, True)#flip horiz axes res = vs.SetEntityMatrix(rec, (ps[0], ps[1], 0), 90,0,b) vs.SetClass(rec, c) Short movie which shows, that the texture changes alignment if another edge is getting the longest edge. Auto-Texture-Align.mp4 Quote Link to comment
DomC Posted August 30, 2024 Share Posted August 30, 2024 was not able to wait and solved it with a funktion: def get_longest_direction(final_contour): # Define the contour points # Calculate the centroid (center) of the contour centroid_x = sum(point[0] for point in final_contour) / len(final_contour) centroid_y = sum(point[1] for point in final_contour) / len(final_contour) # Initialize variables to keep track of the longest edge and its direction max_distance = 0 direction = '' longest_edge_points = () # Iterate over the points to calculate x and y distances between consecutive points for i in range(len(final_contour)): # Get the current point and the next point in the list (wrapping around at the end) x1, y1 = final_contour[i] x2, y2 = final_contour[(i + 1) % len(final_contour)] # Calculate the x and y distances x_distance = abs(x2 - x1) y_distance = abs(y2 - y1) # Check if x distance is the longest so far if x_distance > max_distance: max_distance = x_distance direction = 'x' longest_edge_points = ((x1, y1), (x2, y2)) # Check if y distance is the longest so far if y_distance > max_distance: max_distance = y_distance direction = 'y' longest_edge_points = ((x1, y1), (x2, y2)) # Determine the position of the longest edge relative to the centroid (x1, y1), (x2, y2) = longest_edge_points # Check the relative position of the longest edge if direction == 'x': if centroid_y > y1: # Edge is below the centroid position = 'below' else: # Edge is above the centroid position = 'above' elif direction == 'y': if centroid_x > x1: # Edge is to the left of the centroid position = 'left' else: # Edge is to the right of the centroid position = 'right' return position longest_direction = get_longest_direction(final_contour) '''and for the mapping this code''' vs.SetDefaultTexMapN(rec, 3, 0) vs.SetTextureRefN(rec, texRef, 0, 0) # flip horizontal #vs.SetObjectVariableInt(rec, 540,1) vs.SetTexMapBoolN(rec, 3, 0, 7, False) vs.SetTexMapBoolN(rec, 3, 0, 5, False) #texture part, overall is 3. Selector: init:1, flip:2, repH:3, repV:4, long edge:5, worldZ:6, auto align:7 angle = 0 if 'links' in c: if longest_direction == 'left': angle = -90 * (pi / 180) if longest_direction == 'right': angle = 90 * (pi / 180) elif longest_direction == 'above': angle = 180 * (pi / 180) if 'rechts' in c: vs.SetTexMapBoolN(rec, 3, 0, 2, True) if longest_direction == 'left': angle = -90 * (pi / 180) if longest_direction == 'right': angle = 90 * (pi / 180) elif longest_direction == 'above': angle = 180 * (pi / 180) vs.SetTexMapRealN(rec, 3, 0, 4, angle) Quote Link to comment
