MartynHowes Posted November 21, 2018 Share Posted November 21, 2018 Hi VW hive, I have been asked to add a column within the window schedule worksheet that details the wall style that the windows sit in. i.e. Window W01, 1000mm width, 1400mm tall, First Storey, Sash opening, Wall type 5 Has anyone done something similar to this? I have added a column that recalls "WallTypeName" (function) but the output is always '#TYPES!' (see attached image) I am possibly (probably) missing something obvious here but I can't find an alternative output that would list the wall types that the windows are in. Could someone please help :) Quote Link to comment
michaelk Posted November 22, 2018 Share Posted November 22, 2018 I don't think the window can report the wall that it's in. You can use one of the user fields. Change the record to Window and the field to User Field 1. Then you can type, copy, paste anything you want. The data will be attached to the actual window. Quote Link to comment
