Oliver Hauser Posted October 27, 2018 Share Posted October 27, 2018 Hi Guys, Is anyone else experiencing problems with the stage tool in VW2019 SP1? The default height in the OIP says 1219mm but when I change to Front View or any other view for that matter, the stage is flat (0mm) Any help would be appreciated. Quote Link to comment
markdd Posted October 27, 2018 Share Posted October 27, 2018 Not seeing that particular problem, however the leg count function in the OIP is broken on my version (although it works in a worksheet and on the text display function) Quote Link to comment
Oliver Hauser Posted October 29, 2018 Author Share Posted October 29, 2018 Hi @markdd, I think you might be referring to the "Stage Deck" tool. I'm referring to the " Stage" tool. Let me know if you have the same issue. All the best. Quote Link to comment
markdd Posted October 29, 2018 Share Posted October 29, 2018 Ha. You're right. I was! I haven't used the stage tool for ages and reckoned it had been largely superseded by the Stage Deck tools. However, its part of the program and should work! It doesn't here either. Will you report it as a bug? Mark Quote Link to comment
Oliver Hauser Posted October 29, 2018 Author Share Posted October 29, 2018 Hey Mark, Glad to hear I'm not the only one. I use the Stage tool every now and then to redraw theatre stage layouts. Quick and easy to draw over PDF's with it. Yeah, I sure will. Quote Link to comment
