NicolaO
Planting plan problems
I'm trying to put together a planting plan and am experiencing problems I haven't had before.
When I import a plant from the resource browser it works absolutely fine.
However, when I 'duplicate' a plant to make a new entry and then place it onto my design layer, the plant disappears and can't be selected or edited unless I close and reopen the program, or go to a sheet layer and then go back into the design layer again.
2083803945_ScreenShot2018-07-30at13_42_25.thumb.png.f1a3ef323aca3fbdd733655e9c2c4960.png
Also for some reason, these plant entry symbols are appearing smaller than the ones which I have imported from the resource browser when I view them all in the resource browser and I wondered if this is also connected to the above problem?
1692944849_ScreenShot2018-07-30at13_02_28.thumb.png.6e42b82dd1b166a6fcd3a0f76ac25933.png
I'm sure the answer is obvious, but I don't know my way around VW very well! Many thanks.
If you restart the machine, does it behave the same way after? If so, reply back with the following from that machine please:
Have you turned off the None class? This can cause Plants to become invisible, even if they are not members of the None class.
