I have made 3d symbol of furniture and added a callout (even tried just adding text with a line) to the side and front view to label the furniture item I made. When I do the elevations of the 3d symbol then text go away when I render in hidden lines. I have to do hidden lines for the sheets.
The reason I did this is do when I move the furniture symbol on the furniture plans the label with follow the 3d item on the plan.
I have made the elevation and then added the text in the elevation on my last project but would spend days making sure that I moved all the label to the new location on each elevation.
This should not be this hard. Are there any other designer that have found a way to attach the label to the 3d item that stays with it on plan view and elevation and show up the in hidden lines.
Ellen-Portfolio
2 answers to this question
