MikeN Posted September 27, 2004 Share Posted September 27, 2004 I've got a buch of contour lines in 3d poly format and set at the correct elevations. Everytime I run the DTM Site Survey command I get a message that reads, "A Miscellaneous Error Has Occurred (20,2)" Could this message be more vague? Anyone have any suggestions as to what might be wrong? I've run this command dozens of times and had excelent resluts until now. Quote Link to comment
Guest Posted September 27, 2004 Share Posted September 27, 2004 Either you have overlapping data, or there are too many vertices for the processor to handle. First, rule out having contour lines that overlap. Run Check 3d polys from the AEC menu. If you do that and no polys are crossing, then you'll need to run the filter command under the AEC menu. Quote Link to comment
Jonathan Pickup Posted September 28, 2004 Share Posted September 28, 2004 Katie, can't have somewhere on the help guide to tell us what these error messages are, and even better telling us how to fix the errors... Quote Link to comment
