MartinaL
Wall under door
Hi, I'm using VW2017
While inserting a door in wall with the plug-in object I have a piece of wall between finish floor (where the door is) and top of structure (where the wall has hit bottom bound)
How can I get rid of it?
I managed to change the wall hole just by creating a symbol from the original door and adding a 3D Wall Hole component. What if I want to keep it a plug-in object? Doing this also creates a hole in the floor under the door, that I filled with small portion of slabs that I am forced to manually draw every time I use a door symbol.
First image plug-in object door with unwanted wall under it
Second image Symbol door with hole in the floor
Thank you for your help
Martina
The bottom of the door opening should be at Finish Floor level. So, in the Story Level settings, set your Finish Floor and Top of Structure to the same level.
