MartinaL
    26
Everything posted by MartinaL
  1. Thank you very much @Pat Stanford for your time and your help. I hope we can catch up about this soon! Martina
  2. Hi Christian, I live in Italy and the subframe, in this case, is made of wood planks and closed with aluminium. It is made to eventually locate roller shutters and/or mosquito nets, if the clients decides to pay an extra for them. Here's an other example, from the same producer and an other one from the internet, withe the subframe in blue. Maybe in the blue oneI could use the shim gap? I'm also using windoor, but also in that I can't find the answer.
  3. Hi everyone, I'm writing to try to understand how I should represent using the window tool the subframe (also called false frame) of an aluminium window. I would like to schematize the detail I received from the manufacturer using the window tool parts. I need to schematize the subframe to give the correct wall "hole" (rough opening) value to the building company that has to leave the right empty space in the framed structure to install the windows later. The wall structure is made of steel frames, similar to "light steel frame" by Knauf. Can anyone help me? I used the jamb to create the correct Rough Opening Width and the Rough Opening height (attached) but I know it's not the correct way to do it. Any ideas? thank you, Martina
  4. Just adding more screenshot for clarity.
  5. Hello @Pat Stanford, I'm sorry for bothering you again with scripting, but I have an other issue. With this second script the door names are ordered ascending, but the summarize items spreadsheet option for the 'name' does not work properly. In the DOOR TEST 1 I used the SortedPsetValueAsCriteria script and database header, as a result the PE-01 are not correctly summarized and the PE-02 are correct. In the DOOR TEST 2 I used the PsetValueAsCriteria script and database header, as a result the PE-01 are correctly summarized and the PE-01 are correct. Maybe there's a summarizing option to be added to the script? That way I suppose it won't be possibile do de-summarize the results using the spreadsheet options, right? Thank you again for your time. Martina
  6. @Pat Stanford Thank you very much Pat,the instructions are perfect and you solved my problem! Just one more question: after changing the database criteria to a DatabaseByScript, the Spreadsheet Sort (Ascending, Descending, None) doesn't work anymore; I tried using both a GETIFCPROPERTY spreadsheet formula and a Record Door formula, but I doesn't work anyway. Is there maybe anything that could be added to the script to Sort the results by IfcDoor.Name ascending? If not, thank you very much anyway. Martina
  7. Hi, I have the same problem, even if I'm trying to filter the worksheet with the criteria Pset_DoorCommon IsExternal true. Is there anything new? I'v also seen @Pat Stanford's reply with a script to select a custom IFC property here but I don't know if there could be a way to use something similar for worksheets. I just would like to know f there's a way to do it or if I have to find a workaround. Thank you, Martina
  8. Hello, I have the exact same problem about summarizing walls (the component wall column should be summarized too to see the components correctly) Is it maybe possibile to write a spreadsheet function to show every value of the 'style.mark' just once? I'm not very able to write custom functions, and maybe there's something I'm missing. Could maybe @Pat Stanford help us? I've seen you answered similar questions about worksheets and summarizing. Thank you, Martina
  9. Hi Stephan, I'm sorry but the file was sent me by an external studio that designs furniture. Thank you anyway, Martina
  10. Thank you for your answer, this is the file I used to try to create the legend. Hope you can help me make it work. Thank you again. Martina -Prova 20220114 etichette.vwx
  11. Good evening, I'm writing because I'm trying to create my own worksheet in interiorcad, to use as an automatic legend in my sheet layer. (see attached screenshot) I was able to filter the cabinet and to show some values as, for example, the Board ID using ='Custom Part - Material'.'Board' but I can't show the most important value, the material Description (as I made my own material database in the interiorcad-Master Data-Edit Boards... menu) I've seen that in the template lists of interiorcad this value I'm looking for is visible with the command [BoardDescription] but I'm not able to transform this in a worksheet string. Is it possibile to do it, so I can better organize my own legend? Thank you in advance, Martina
  12. Good morning, any news about the topic above? As for a similar question, I'm trying to customize unit groups, changing names (description) and description to make it easier for me to use it, but no change seems to do anything, it goes back to how it was for example if I change the name of "Side" in "Laterali" it goes back to his original name. Am I doing anything wrong? Thank you, Martina
  13. Good morning, any news about the topic above? As for a similar question, I'm trying to customize unit groups, changing names (description) and description to make it easier for me to use it, but no change seems to do anything, it goes back to how it was for example if I change the name of "Side" in "Laterali" it goes back to his original name. Am I doing anything wrong? Thank you, Martina
  14. Hello, Im using Vectorworks 2021 SP1 and I just tried to use the VBvisual Plant Tool - More Plants but it gives me an error page and I can't download more plants. Do you know any website where I can download new plants to complete my design? I'll prefer not to use the Plant tool because the Top Plan view is mostly terrible. Best regards, Martina
  15. Hello, I would like to create a worksheet database whose criteria are "select all walls with the Pset_WallCommon IFC value Reference IWS-1** because here is the wall style Mark I want to use to divide my walls I tried the string =DATABASE((('Pset_WallCommon'.'Reference')='IWS-1**')) but it gives me no results, like it cannot read the IFC property When I use that field in a spreadsheet it requires the string =GETIFCPROPERTY(‘Pset_WallCommon’.’Reference’) so maybe I need to recall the IFC property some way? I tried some variants but nothing worked, can someone help me? Thank you very much
  16. Hi, I have a wall Style made of various components and classes and I assigned it a fire rating value, for example this I would like to be able to highlight every wall's fire rating and obtain something that looks like this I created a custom line style that looks like this. Then I selected the rei properties of the wall styles with data visualization I don't know how to edit attributes to make things show. Editing pen style has no result. I know I could manually draw the lines in viewport annotation but I want it to happen automatically. I also created a custom tile to edit the fill attribute of the wall but the result is not as I expected. Any advice? Thank you in advance Martina
  17. I know, but this is not the point. The interior elevation viewport sections lines ARE normal to the camera but changing their length makes them no more capable to display 2D components. What I was saying is that you cannot rotate section lines while in "edit section lines" command.
  18. Thank you very much, it was super helpful! Have a nice day Martina
  19. Hi, I'm sorry I wasn't clear enough. My wall styles have a wall style name that indicates certain characteristic of the wall, so I'd like to sort them according to this name to sort them by these characteristics. For example I want to keep out from the list all the ones starting with Cw or Cwc or ICw (my counter walls). So I select "type - is - wall" and than "Name - does not start with - Cw_*" What I expect is to have listed wall style names but not the ones starting that way, but as it shows in the previous screenshot there are names that should't be there like Cw_a P2 or Cwc_R.h P2 etc. So I suppose I did something wrong. Could you help me? Thank you again for your nice reply, I really appreciate that.
  20. Hi elepp, thank you for your quick and niece answer! Unfortunately this syntax is not working, it gives me the same results as before; maybe I did it wrong? Thank you very much
  21. Hi, I'm creating interior elevation viewports of some rooms in my project, after creating them if I move the section lines to make them longer or shorter (nothing happens moving them in the other direction) to include walls in the section the viewport loses the capacity to display 2D components of the symbols I inserted. It seems to lose the "normal to the camera" position even if I carefully move the snaps (it is not possible to rotate the section line anyway). I think it happens because my walls are all rotated; I tried to do the same with aligned walls and there's no problem. Even if I work in rotated top plan mode the problem still shows. Do you maybe have any suggestions? I cannot rotate all the drawing to align the walls with the UCS. By now I am creating interior elevation viewports without the walls, but I'd prefer to have them, for a more complete drawing. Thank you very much Martina
  22. Hi, I'm creating my reports and to do so I need to sort my wall styles by name. Even though the wall style name is in the list of possibile answers, when I try to use the "starts with" or "ends with" "contains" etc the answer is always wrong, it is either zero or all of them. Am I writing things the wrong way and/or with the wrong syntax? Is there any other way to sort wall styles in the same class and in the same layer? Thank you in advance Martina
  23. Hello, I'm trying to put in my project this external sliding door. I cannot find the correct options in the door PIO (maybe someone can help me?) Otherwise I created this simple 2D/3D Symbol with the correct wall hole, but in top/plan view the wall is cutted the wrong way, even if in top view it's correct. How can I solve this visualization problem? I want to keep it a symbol or a PIO, so no groups. I have read on this forum about a plug-in for Vectorworks named Windoor but I have VW2017 and I don't think it's available in Italy. Here some screenshots Thank you
  24. Hi, When I use a section viewport to display the inside part of the building I can display the space fill as I prefer but I can't see the label of the space; at the same time I am not able to assign ID labels to walls and elements that are visible in section viewport and/or in elevation Is there a way to have those IDs visible? what am I missing? Thank you very much I have VW2017
