BG Posted March 13, 2018 Share Posted March 13, 2018 I would like another option added to the Select Similar Tool Preferences. 'Locked' or 'Unlocked'. It would be good to be able to select objects that are either locked or unlocked. Thanks Quote Link to comment
0 Art V Posted March 15, 2018 Share Posted March 15, 2018 I like this wish so +1 though if you only need to unlock objects you can do a select all and then do the unlock. If it is for changing to another layer, again select all and only the unlocked ones should move over. That being said, if you need to make a very specific selection of objects that are also locked or unlocked then it comes in handy to have this option depending on what you want to do. It would be even nicer if this locked/unlocked state could also be added to the custom selection where it can be equally useful as with the select similar too. Quote Link to comment
BG
Thanks
1 answer to this question
