DaveCarr
Worksheet Images
Hi All,
I have just experimented with Images in worksheets and can not figure out how to turn off some of the classes so only the basic part of the image is displayed.
In the attached image, i would like to turn off the fixture info and on the truss i would like to turn off the "truss Simplified" Class and in the "1/2 ton" symbol i would like to turn off everything but the symbol it's self
Thank you!5a5ce3406a3df_keyscreenshot.thumb.PNG.815604d90488607be9e685cdb5bfe898.PNG
When you update the worksheet, you need to have the classes that control fixture info etc turned off. That should do it.
Mark
Emphasis on the "should". In previous versions this was definitely the case, but if you are using VW2018, beware that there is a bug that affects how symbols appear in worksheets using the =IMAGE function.
I have been told that a fix to this bug is expected in SP3 which should be forthcoming soon I think, but just worth noting.
Thank you for the info. and the "should" work...
I just double checked and my classes were off on a couple of items. Thank you! i will eagerly be awaiting sp3
Dave Carr
Dave's World Designs
