SarahISO Posted December 18, 2017 Share Posted December 18, 2017 Hi All, Having a recurring problem when applying textures to objects in Vectorworks 2018 - See image attached. I will be working on a project and apply textures fine with no issue, then for some reason when I start changing existing textures or try to create new ones the image in preview will show lines/weird pixelated images (like when your tv/computer screen looses connection) and then the texture on the object will look the same as the image (sometimes it actually looks how it should but mainly the texture will corrupt too). Any ideas how I can fix this? Quote Link to comment
zoomer Posted December 18, 2017 Share Posted December 18, 2017 I also see corrupt previews. And I also wonder how the broken thumbnails can appear on the final Rendering. Or was it in OpenGL only (?) Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 18, 2017 Vectorworks, Inc Employee Share Posted December 18, 2017 Does the same corruption appear after a full machine restart? Could you please post a file where this presents as an issue? Quote Link to comment
zoomer Posted December 18, 2017 Share Posted December 18, 2017 (edited) I am still searching but or now I found a C4D Material File to import which showed these problems too. It is attached at the end of that Thread : https://forum.vectorworks.net/index.php?/topic/45131-c4d-textures-broken/&page=2#comment-261479 (BTW, how to link a special Post only ?) Plus screenshots from another Post : https://forum.vectorworks.net/index.php?/topic/52566-vw-2018-opengl-transparency-of-c4d-materials/&tab=comments#comment-263451 Edited December 18, 2017 by zoomer Quote Link to comment
SarahISO Posted December 19, 2017 Author Share Posted December 19, 2017 (edited) Thanks for your replies, I have attached a file where the texture corruption is happening but only in open GL (Typically the file I was working on yesterday fixed itself after a restart) but I have had it happen where the texture shows 'fuzzy' in final quality render and I have had to create a texture in a new file and link it in to correct the problem. I'll upload another file when it happens again. Thanks, Test.vwx Edited December 19, 2017 by SarahISO Added screen shots Quote Link to comment
SarahISO Posted January 22, 2018 Author Share Posted January 22, 2018 Hi, My colleague has just had the same thing happen on her computer - textures have corrupt, but when I open the file on my mac it's fine and I can change & render the model with the correct texture fine... I've attached the file - can anyone else see the issue? 01_Model.vwx Quote Link to comment
Gadzooks Posted January 28, 2018 Share Posted January 28, 2018 On 22/01/2018 at 11:12 AM, SarahISO said: can anyone else see the issue? On opening, this file is reported as corrupt by VW and I had to force quit. - Thanks for that. BIN IT Quote Link to comment
Guest Selin Posted February 8, 2018 Share Posted February 8, 2018 This seems like a problem in generating the texture preview. If the preview looks weird, OpenGL will just show the weird looking image because it uses the previews. Renderworks should render fine though. When you see this issue, one thing that might help is to edit the texture, tweak a parameter or two and bring it back to whatever value you wanted. This should force a new preview generation. Quote Link to comment
Gadzooks Posted February 8, 2018 Share Posted February 8, 2018 Maybe different on your setup. For me - beach ball...............................force quit. ⛑ Quote Link to comment
Guest Selin Posted February 8, 2018 Share Posted February 8, 2018 @Gadzooks oh yeah that 01_Model.vwx file says it's corrupt after opening for me too. Quote Link to comment
