zero Posted May 26, 2004 Share Posted May 26, 2004 Hi All Has anyone worked out a good way to align annotations (eg the drawing label) on differnt viewports? Does the question make sense? Thanks Mat Quote Link to comment
CipesDesign Posted May 27, 2004 Share Posted May 27, 2004 Mat, If you place your drawing titles on the SHEET LAYER instead of in the viewport this is easy to do. Peter Quote Link to comment
zero Posted May 27, 2004 Author Share Posted May 27, 2004 Thanks Peter You are right about that, but, what if you have viewports of different scale on the same "sheet" (of paper), then your drawing label will report an incorrect scale for some of the viewports. Also, it's not just drawing labels; whole blocks of text look better aligned to other blocks of text - same with dimensions. Is there a hidden "switch" to "show other viewports wjile editing viewport" similar to "show others while in group"? thanks again MAt Quote Link to comment
CipesDesign Posted May 27, 2004 Share Posted May 27, 2004 Mat, Point 1: In the Drawing Label, choose "SCALE DISPLAY STYLE>CUSTOM" then you can type in anything you want. (BTW, I rarely use the Drawing Labels because I have my own custom ones.) Point 2: I totally agree and am very picky about how things layout on sheets. To align blocks of text you might try using the menu item TOOL>ALIGN>ALIGN DISTRIBUTE. Or you could copy the first one, move it horizonatal (for example) then enter and edit the text. Point 3: I don't think so, but am not sure. Peter Quote Link to comment
