I found this inconsistency today that I hadn't noticed before. Is anybody else experiencing it and do you think its working as designed? You can offset simple Flat Plane Nurbs surfaces. The tool keeps all attributes the same with the offset surface apart from the texture, which reverts to the class texture. In the offset Original Object Mode, isn't the tool just meant to offset the object?
Offset_tool_inconsistency.mov
Offset Nurbs.vwx
