lisagravy Posted September 19, 2017 Share Posted September 19, 2017 (edited) Is there an easy way to smooth my site model without losing too much accuracy? I have little jaggy bits showing in my OpenGL render everywhere between my stake points, as per images! Affecting some contours too. Edited September 19, 2017 by lisag Quote Link to comment
Urbanist Posted September 20, 2017 Share Posted September 20, 2017 The DTM engine has had quite a few quirks with valleys ans swales, the algorithm does not look ahead, but connects closest points in a non-topographic way. I've had a few terrains that VW simply failed to model correctly. The most disappointing one was about partial filling and landscaping a former open-pit mine which would have been a quite significant project, especially fee-wise and also because there might have been several similar ones. I even considered getting AutoCAD, but with no required skills or machinery, just had to give up and decline to tender. Thank you, Mr. Vectorworks! Quote Link to comment
lisagravy Posted September 20, 2017 Author Share Posted September 20, 2017 I'm glad it's not just me, though am frustrated and disappointed that there's not an easy fix for this? We had assumed using landmark for topographic modelling would be straightforward....... Quote Link to comment
Urbanist Posted September 21, 2017 Share Posted September 21, 2017 On 9/20/2017 at 0:30 PM, lisag said: I'm glad it's not just me, though am frustrated and disappointed that there's not an easy fix for this? We had assumed using landmark for topographic modelling would be straightforward....... Unfortunately terrain modeling is anything but straightforward. As someone from the old school I like to think new landforms with contours. Luckily I do a bit of programming and was able to create a semi-satisfactory contour tool. It of course does ot help with the problems of the DTM engine itself. All these pads and what have you may be fine for architects who deal with small houses on topographically simple sites, but they are next to useless in landscape architecture. Not sure about garden design, never done that. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted September 21, 2017 Vectorworks, Inc Employee Share Posted September 21, 2017 On 9/20/2017 at 5:30 AM, lisag said: I'm glad it's not just me, though am frustrated and disappointed that there's not an easy fix for this? We had assumed using landmark for topographic modelling would be straightforward....... Would you mind sending me that file? The Site Model on it's own in a test file would be perfectly fine. Feel free to direct message it to me if you do not want to post it publicly. Quote Link to comment
Miguel Barrera Posted September 21, 2017 Share Posted September 21, 2017 Adding 3D polygons between co-linear 3D points should fix the problem. As illustrated in your images, there are some points that cross the co-linearity of the the 3D points but if you add a 3D polygon or line, the DTM triangulation algorithm will not cross the line. Quote Link to comment
Benson Shaw Posted September 21, 2017 Share Posted September 21, 2017 3D polys as Miguel says or 3D loci, add them at correct z between the contours. Here's a vid: https://vimeo.com/195211767 -B Quote Link to comment
