pdoran Posted May 11, 2004 Share Posted May 11, 2004 There are a number of style options available as choices within the stair tool preferences dialog box (objects pallette), but are only identified by a number ("style12"). Is there a descriptive reference available anywhere as to what these styles are? Mac v 10.5 Quote Link to comment
Guest Posted May 11, 2004 Share Posted May 11, 2004 There are no pre-set styles for the styles. When you select a style from the OIP, a class with that name is created. You need to then go to the classes dialog box and set the desired texture settings to that class. Quote Link to comment
Petri Posted May 12, 2004 Share Posted May 12, 2004 Katie, you SHOULD tell how these style (class) names are modifid to be useful or point the person to the appropriate tech note or manual section. I'm sick and tired of giving the same instructions over and over again. Quote Link to comment
Hunter B Posted May 12, 2004 Share Posted May 12, 2004 I didn't know you HAD to tell everbody, Petri... what stress that must cause. Good Luck. Quote Link to comment
