John Callan Posted March 17, 2004 Share Posted March 17, 2004 The stair PIO shows up as a 2D object when the rest of the drawing is viewed as 3D. The create 3D box is checked. Sometimes if I ignore it, I find it working normally the next day. Sometimes I delete the stair and insert a new one. Any idea what I'm doing that is making this happen? Thanks. -jc Quote Link to comment
zero Posted March 17, 2004 Share Posted March 17, 2004 Have you inserted the stair on a different layer? Quote Link to comment
John Callan Posted March 17, 2004 Author Share Posted March 17, 2004 No. The stair is on the same layer as walls and floors, columns, etc. All appear in 3D in Iso view, except the stairs. Quote Link to comment
Guest Posted March 18, 2004 Share Posted March 18, 2004 Does it work correctly in a new, blank document? Quote Link to comment
John Callan Posted March 18, 2004 Author Share Posted March 18, 2004 Yes. I tried a new stair pio in the new document, the pio from the document I am concerned with, and I copied the stair from the document. All three appeared correctly in the new document, in both 2D and 3D. Suggestions? -jc Quote Link to comment
Guest Posted March 19, 2004 Share Posted March 19, 2004 In the bad file, are you using the actual stair tool, or a symbol created from a stair tool ? You may want to expedite eveything and email it to tech@nemetschek.net to have them investigate the issue. Quote Link to comment
John Callan Posted March 19, 2004 Author Share Posted March 19, 2004 I'll send the file, as suggested. The file doesn't appear to be "bad", in any other way. Thank you. -jc Quote Link to comment
Christiaan Posted September 5, 2005 Share Posted September 5, 2005 Was this issue ever resolved? I have this same problem. My 3D stair shows up only as a 2D object in 3D view . [ 09-05-2005, 08:24 AM: Message edited by: Christiaan ] Quote Link to comment
