minotto Posted May 12, 2017 Share Posted May 12, 2017 I'm just learning about worksheets and generating reports. I've created a worksheet for a wall style and have 2 issues i can't resolve. 1) When multiplying Net Area and Price/ SqFt, the numbers are off. (The functions maybe wrong?) 2) Using =COMPNAMEBYCLASS i have the wall components listed to determine price/sqFt. but the total Net Area for each component and the wall styles don't match up. Or are they not supposed to? Attached is the file. Any insight into what i'm doing wrong is greatly appreciated. Worksheets.vwx Quote Link to comment
michaelk Posted May 12, 2017 Share Posted May 12, 2017 Look in File > Document Settings > Units. Your file has the area precision set to 1. So in the worksheet it displays the the area rounded off to the nearest whole number, but in the calculation it uses all the decimal points it has. A couple options: 1. Increase the precision of the document area units. 2. If you want the area to display in whole units then round it in the worksheet. Then the calculations will use the rounded value and not the actual, hidden value. To do this just use the existing function call inside a ROUND Function. So in Column C the =WALLAREA_NET call would be =ROUND(WALLAREA_NET) Quote Link to comment
minotto Posted May 12, 2017 Author Share Posted May 12, 2017 Thanks a lot michael. I changed the function to ROUND and it adds up right now. One other thing though, why do the components and the Wall Style have different Net Areas? Shouldn't they all be the same? Quote Link to comment
michaelk Posted May 13, 2017 Share Posted May 13, 2017 The component on the outside of a corner is going to have more area than on the inside of that corner. The difference will be the thickness of the connecting wall. So the exterior components will usually have more area than the interior gyp board. If you draw a single straight wall with no corners all the components will have equal area. Quote Link to comment
minotto Posted May 13, 2017 Author Share Posted May 13, 2017 Right that makes sense. Thanks again for your help. Quote Link to comment
