Set visibility parameters in default PIO
rebu1985
Hi guys,
I have done a script to hide some fields of the default PIO 'Desk' because I just need some parameters to work. The plug-in is compiled right but when its not working because nothing is done. My version is VW14.
My idea is to create different script for default PIO doors and windows but using a few parameters.
My script is below:
PROCEDURE Modifydesk;
VAR
objHd: HANDLE;
BEGIN
objHd:= GetObject('Desk');
    IF objHd=NIL THEN
    EnableParameter(objHd, 'Leg Height', FALSE);
    SetParameterVisibility(objHd, 'Leg Height', FALSE);
END;
RUN (Modifydesk);
To start, you have a few issues with your script in general:
- Your if statement tests to see if the handle is empty, so your then case only executes if handle acquisition is unsuccessful
- You have two statements that are a consequence of your if statement, so you need to put them in an if/then block.
Also, the parameter calls are designed to work on a plug-in instance rather than the plug-in default, the latter being the handle you retrieve.
The following script will affect the visible parameters of the selected instance of a Desk object:
VAR
objHd: HANDLE;
BEGIN
	objHd:= FSActLayer;
	IF objHd<>NIL THEN BEGIN
	END;
END;
RUN (Modifydesk);
A couple other things to note.  The OIP needs a refresh, so de-select and re-select the object to see the OIP refresh.  These commands are really meant to run from inside the plug-in code, so as soon as you change one of the plug-in’s parameters, the OIP resets to show the field.
So, unfortunately, customizing the display options for plug-ins that you don’t code or don’t have that as an explicit feature isn’t possible.
-Josh
