J. Wallace Posted February 8, 2017 Share Posted February 8, 2017 I haven't used the command 'Text along path' before, not sure why, but I'm having some challenges with text orientation. It seems that the text wants to appear upside down, any helpful hints would be much appreciated. Thanks Quote Link to comment
bcd Posted February 8, 2017 Share Posted February 8, 2017 It has to do with the direction the Path was drawn. To edit the direction Right Click the Text Along Path object, Edit Path>Select>Reverse Direction>Exit Path Some objects allow you to do this from the OIP of the object <-Wish 1 Quote Link to comment
J. Wallace Posted February 9, 2017 Author Share Posted February 9, 2017 Thanks for that @bcd I'm quite surprised that after sending the text along path that you are unable to edit the text itself. Bummer. Quote Link to comment
bcd Posted February 9, 2017 Share Posted February 9, 2017 (edited) You can, but it's called the Profile in this case. Rightclick>Edit Profile Edited February 9, 2017 by bcd 1 Quote Link to comment
