Fredrik Amn Posted October 30, 2003 Share Posted October 30, 2003 Hi, I?m trying to do a simpel hidden line rendering of a table with two tv-monitors and a keyboard on, but it takes ages to render. like i said, I?m just trying to to do a hidden line rendering witch shouldent take more than a few seconds, but i takes about 15 minutes. This realy drives me crasy and more worse is that it slows my work down extremly.... If anyone have a clue what does this, pleeeease help me.... Kind Regards / Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted October 30, 2003 Vectorworks, Inc Employee Share Posted October 30, 2003 quote: Originally posted by Fredrik Amnes: I?m trying to do a simpel hidden line rendering of a table with two tv-monitors and a keyboard on, but it takes ages to render. Contact tech support or send the file (with an explanation of the problem, and a description of your system like you had in your posting) to bugsubmit@nemetschek.net. There's really no other way for us to diagnose the issue. Quote Link to comment
Bryan_dup1 Posted October 30, 2003 Share Posted October 30, 2003 I don;t have an answer for you, but have had the same problem. My work around this issue is to use the "tool/convert copy to lines/hidden line" which works much faster. I notice that you have Vector Works 10.5 with ArtLantis 4.5. Do you have problems with the Artlantis supplied translator like I have? Quote Link to comment
propstuff Posted October 30, 2003 Share Posted October 30, 2003 I'd agree with Fredrik's observation; For realatively complex 3D objects hidden line renders take about 2-3 times as long as a Final render with transparency, shadows etc. This started (I think) with VW10 The convert copy to lines is what I do also. N. Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted October 31, 2003 Vectorworks, Inc Employee Share Posted October 31, 2003 quote: Originally posted by Fredrik Amnes: If anyone have a clue what does this, pleeeease help me.... One question is whether you've set your smoothing angle to a non-zero value. This removes the non-profile lines between faces on on most curved surfaces, which can significantly speed up rendering. Set it to 1.0 and see if that helps. Hidden line rendering may take much longer than raster rendering (OpenGL/RenderWorks) simply because it has to consider the potential interaction of every surface with every other surface in the drawing. Quote Link to comment
Fredrik Amn Posted October 31, 2003 Author Share Posted October 31, 2003 I notice that you have Vector Works 10.5 with ArtLantis 4.5. Do you have problems with the Artlantis supplied translator like I have? No, i?ve had no problems at all with Artlantis, works perfectly every time.... I don;t have an answer for you, but have had the same problem. My work around this issue is to use the "tool/convert copy to lines/hidden line" which works much faster. The thing is that "convert copy to lines/hidden line" is just as slow, it also takes about 15 min just for a simpel drawing... I?ve tested all kind of alternatives with "smoothing angel" butt no luck..... anyone have a clue? Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted October 31, 2003 Vectorworks, Inc Employee Share Posted October 31, 2003 quote: Originally posted by Fredrik Amnes: The thing is that "convert copy to lines/hidden line" is just as slow, it also takes about 15 min just for a simpel drawing... You could try "hiding" bits of your drawing (group an object, then assign the group to an invisible class) to find out whether one particular object is causing the slowdown. It may be that a small, highly-detailed object that has little visible effect on the result taking much of the time, and you can replace it with a simpler version, at least for doing hidden line renderings. Quote Link to comment
Fredrik Amn Posted November 4, 2003 Author Share Posted November 4, 2003 Ok..... i?ve tried that now. I came to the conclution that it was the symbols that slowd the whole thing down........... butt why??? They are very simpel symbols! I cant make them much simpler, and i cant remove them becouse they are esential to the drawing. Confused......... Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted November 4, 2003 Vectorworks, Inc Employee Share Posted November 4, 2003 quote: Originally posted by Fredrik Amnes: Ok..... i?ve tried that now. I came to the conclution that it was the symbols that slowd the whole thing down........... butt why??? If you convert the symbols to groups, is it still just as slow? What is in those symbols? Quote Link to comment
