Mike Wright Posted December 13, 2016 Share Posted December 13, 2016 I'm either missing something or VW is I can find no way to change a selected bunch of instruments to 'lit fog' on or 'falloff' on I have to click through each instrument and 'edit light' which is quite time consuming. Any help? VW2017 Quote Link to comment
markdd Posted December 13, 2016 Share Posted December 13, 2016 Use the visualisation palette and make a multiple selection. That should work Quote Link to comment
Mike Wright Posted December 13, 2016 Author Share Posted December 13, 2016 yeah that works but as there is no way in the vis palette to identify the instruments it takes almost as long to find them! Quote Link to comment
markdd Posted December 13, 2016 Share Posted December 13, 2016 If you fill in the channel field or purpose field then that will appear in the visualisation palette Quote Link to comment
Mike Wright Posted December 13, 2016 Author Share Posted December 13, 2016 brilliant, would be great if that had been made obvious at some point in the documentation! thanks! Quote Name Displays the name of the light (as shown on the Data tab of the Object Info palette) Quote Link to comment
