AlanW Posted October 26, 2016 Share Posted October 26, 2016 (edited) Hi, In the attached file I have tried to use the Get object Count node without success. Have run a spreadsheet to do the count and check the criteria. Any ideas please. Thanks Ok so I should have read it better. the node actually only counts items on the current design layer. So now to code the node vs,Count unless there is one in the Default anywhere??? Untitled1.vwx Edited October 26, 2016 by Alan Woodwell Quote Link to comment
Marionette Maven Marissa Farrell Posted October 26, 2016 Marionette Maven Share Posted October 26, 2016 Hey Alan, It appears that the Get Object Count node is improperly labeled at its ports. The input should actually be a LAYER, as the node will count all of the objects on a specific layer. I think that for what you're trying to accomplish, you can use "Get List Length" from the Data Flow category. I'll be sure to update that node to be more user friendly as soon as I can. Thanks for pointing this out! 1 Quote Link to comment
AlanW Posted October 26, 2016 Author Share Posted October 26, 2016 @MarissaFThanks for that it worked a treat. Someone asked if it was possible to count the mesh object in Vectorworks and I though Marionette and now I can do it. Quote Link to comment
