  • 2
Combining nurbs surfaces
Samuel Derenboim
Perhaps I'm not aware, but I don't think there is a way to add multiple nurbs surfaces into one monolithic modifiable surface without creating a geometric object? (this is what happens when you compose those surfaces)
common workaround is to use the divide by distance tool and then redoing the nurbs surface, however the process is quite cumbersome of redoing the entire surface if you have a lot of segments. Just wanted to put that out there.
Edited by Samuel Derenboim
2 answers to this question
