Mulk Posted August 27, 2016 Share Posted August 27, 2016 Hey guys, I'm having a problem with the light pipes tool. In the file I've been working in it will only show the newly drawn pipe in 2d mode and won't bring it into 3d. If I open a new file the tool works as expected, and copying from the new file to the working file makes the light pipe misbehave. Has anyone else had this problem? Quote Link to comment
RickR Posted August 27, 2016 Share Posted August 27, 2016 I suspect your 3D parts have gotten onto a class that's off. Do you see anything when "show footprint" is on? Quote Link to comment
JBenghiat Posted September 6, 2016 Share Posted September 6, 2016 Both the 3D component and the single or double line of the 2D component are in a class, visible in the OIP. If you have Auto-Class enabled, this is in the -Pipe subclass. You can also set these components to be in the overall object's class. If you see the pipe in 2D, you may be looking at the pipe's footprint and not the actual pipe. HTH, Josh Quote Link to comment
