AlanW Posted August 21, 2016 Share Posted August 21, 2016 (edited) Hi, I would like to have the resultant object placed on Design layer2, Node is on Design Layer 1. Set layer node only gives me the option of Design Layer 1 and Ham??? yup Ham.? Why cant i choose the other design layer to receive the object?? Thanks Edited August 21, 2016 by Alan Woodwell Quote Link to comment
Marionette Maven Marissa Farrell Posted August 21, 2016 Marionette Maven Share Posted August 21, 2016 The set layer node is kind of a pain right now. If you want to update the list to show the layers you have in your document, I believe you have to open the script of the node, close it (you don't have to make changes), run the network again, and at that point the OIP control for the set layer node SHOULD have your actual layers in it. If it doesn't work the first time, follow those steps again. Let me know if you still can't get it to work after that. Quote Link to comment
AlanW Posted August 21, 2016 Author Share Posted August 21, 2016 Yes, You set the design layer to active that doesn't show in OIP and open close and run and the new design layer shows. Thanks Quote Link to comment
