RuudB Posted May 31, 2016 Share Posted May 31, 2016 Hello all, I am building an element with Marionette. This element contains a lot of control geometry that is used for the script. Because many objects within the element need the same handling, I divided it in groups. But the script is not working for these groups. I added an example that shows the desired result (unwrapped) and the not working result (wrapped). Am I making a mistake, or is it a bug in Marionette? Ruud Quote Link to comment
Marionette Maven Marissa Farrell Posted May 31, 2016 Marionette Maven Share Posted May 31, 2016 Ruud, At a first glance, I don't believe you're using Control Geometry properly. Control geometry is defined with the "Control Geometry" node in the Input category. This node will look for objects in your defined control geometry (where you put your group and rectangle objects) At this time, there is no simple support for multiple control geometry objects. Quote Link to comment
RuudB Posted May 31, 2016 Author Share Posted May 31, 2016 Thanks for the quick answer Marissa! I also had contact with the support, same answer. In my real model I am using an element with a lot of objects in the control geometry. I can use all the objects by calling their names, except for the groups. So I am amazed this works somehow. Quote Link to comment
Marionette Maven Marissa Farrell Posted May 31, 2016 Marionette Maven Share Posted May 31, 2016 No problem! The reason you're still able to call objects by name is because that node will look through your entire document drawing area for objects that are of the same name. I'm actually surprised that groups aren't being recognized, to be honest. So regardless of you putting those objects in Control Geometry, leaving them on your Design Layer, or even copy-pasting them into your wrapped script, they should be located by the Name node. I'll try to do some further investigating as to why groups aren't being manipulated, since I really think they should have worked just as they would have in your unwrapped script. Quote Link to comment
RuudB Posted June 1, 2016 Author Share Posted June 1, 2016 I'm trying to understand Marionette better. This information helps a lot! You're mentioning three options where to put the objects used by the wrapped script. Groups aren't recognized in any of them. Even one group in the Control Geometry calling with the "Control Geometry" node won't work. Hope you will find the answer. If you want to see why I need to use a group and to wrap the script, I can sent you my full model. Quote Link to comment
Marionette Maven Marissa Farrell Posted June 1, 2016 Marionette Maven Share Posted June 1, 2016 If you want to send it, I'd definitely love to see it! Hopefully I'll be able to help you troubleshoot and find a solution. You can email it to me at ---, and I'll take a look first chance I have Quote Link to comment
AlanW Posted June 3, 2016 Share Posted June 3, 2016 Hi, if you look at Dom's shared network Brochure holders he uses groups within his control geometry, this may assist. There is a order, front to back which way they are read as I recall. HTH Quote Link to comment
