can Posted June 20, 2003 Share Posted June 20, 2003 i can't rotate a large group og objects ( a layout plan) by any rotation tool. it only show the box message: "this editing operation cannot be performed becase of constraints on one or more objects involved." Quote Link to comment
propstuff Posted June 20, 2003 Share Posted June 20, 2003 Yes, this is a bit of a nuisance. I've found you have to ungroup, do the rotation and then re group {:-[ cheers, N. Quote Link to comment
can Posted June 20, 2003 Author Share Posted June 20, 2003 hi nicholas, thank you for your advises... i've try ungroup the objects and rotate them but failed. i found that is only that object ( a plan) cannot rotate. i can rotate the other huge object at the other file. also i found i could make rotation to a new object that i drew. Quote Link to comment
Guest Posted June 20, 2003 Share Posted June 20, 2003 Do you have a parametric constraint on one of those objects?? Quote Link to comment
can Posted June 20, 2003 Author Share Posted June 20, 2003 hi katie, i haven't use any parametric constraint on my file. so, i don't know why i can rotate that object! can Quote Link to comment
Guest Posted June 20, 2003 Share Posted June 20, 2003 hmm .. that's weird. Can you send the file in? I'll try and take a look at it today. tech@nemetschek.net?subject=ATTN:Katie can't rotate drawing Quote Link to comment
