lchen
how to achieve this object
I am studing marronette .I divide two cicle ,then connect two points ,but in vectoworks it doesnot have 3d line. please help me
see the picture
Hi,
What result do you want? a cylinder?? is so you can loft between then or draw a circle and extrude.
Maybe a picture of what you want as a final object.
Edited by Alan Woodwell
if i use Curve with NURBS,I can not create many lines,only create a line. please the picture
At first you have to bring the points into the right order by zipping the points of circle1 with the points of circle2.
You want to draw N lines which are based on 2 points each therefore you have to chunk the list of points by 2 before they flow into the curvce node.(The 'Chunk List'-Node is not part of the library)
