barkest Posted February 14, 2016 Share Posted February 14, 2016 Hi, I have a SLVP with hidden line and the curved wall (bay) is not showing up. Is this a known problem or just me? thanks Quote Link to comment
rDesign Posted February 15, 2016 Share Posted February 15, 2016 Could it be the SLVP's Hidden Line 'Smoothing Angle'? Set it to zero and see if the curved wall appears. Viewport Properties > Background / Foreground Render Settings > Hidden Line Viewport Properties : Vw2015 Help Quote Link to comment
barkest Posted February 15, 2016 Author Share Posted February 15, 2016 thank you for the reply unfortunately it remains the same after changing the smoothing angle. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 16, 2016 Vectorworks, Inc Employee Share Posted February 16, 2016 Worst case; you can add the line manually via viewport annotations. However, that kind of curve should be picked up by Hidden Line especially if its a Wall object. Send me that file ATTN Jim at tech@vectorworks.net and I can take a look. Quote Link to comment
barkest Posted February 17, 2016 Author Share Posted February 17, 2016 Thanks Jim yes I added the line manually via annotations as a work around. FYI the line does not show on a design layer either. thanks again Quote Link to comment
