herbieherb Posted January 22, 2016 Share Posted January 22, 2016 The Move Node doesn't work on a 2D Object when it's wrapped to an object Node. When it's unwrapped it works. It also works on 3D Objects. I'm a little confused. Quote Link to comment
Patrick Winkler Posted January 22, 2016 Share Posted January 22, 2016 Hello herb, thanks for reporting. I have already made a bug request about this issue. It seems to be related with the german encoding. Quote Link to comment
herbieherb Posted January 26, 2016 Author Share Posted January 26, 2016 Maybe it has to do with the issue reported in that topic? https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=221925#Post221925 Quote Link to comment
AlanW Posted January 26, 2016 Share Posted January 26, 2016 (edited) Hi, Attached is a file showing the move in an Object Node. This has been pulled out of the Caster Object and converted down from 3D move to 2D move. HTH Really strange with your file couldn't get it to move but recreated the same and got to move. Your file is on top, mine below. copy mine out to new file and try, it works but it is exactly the same as yours, well as far as I can see. I think you are right about the coding files are different.(not programmer) Edited January 26, 2016 by Alan Woodwell Quote Link to comment
herbieherb Posted January 26, 2016 Author Share Posted January 26, 2016 Thx you just found the solution. The Node is different in the german version. If i replace my move node with yours it works. I will replace the node in my library. Quote Link to comment
