Sheet Notes and leader Lines
benboggs
Hello - I have a couple of questions regarding Sheet Notes and the associated leader lines and generated sheet notes in the 'paper space' of the sheet.
First image attached - is it possible to make the leader line stop at the hex instead of extending into the center?
Second image - why do the sheet notes in the 'paper space' have a period after the number yet the tags in the view port do not?
Third - is there a way to make it so that the hex does not stretch when the numbers get into the double digits?
Thanks,
Ben
Hi Ben, If you want more control over graphics and are willing to give up some automation (which could be a big trade off), check out the following two "legacy" tools: 1) The Number Stamp Tool (which creates one of many shapes with ordered numbers or letters in each subsequent insertion; 2) The Leader Line Simple Tool (which draws two line segments, the second of which has an arrowhead).
You can add these (or any) tools to your Workspace via the Workspace Editor.
