jmartinarch Posted October 8, 2015 Share Posted October 8, 2015 sometimes my viewport border prints. I don't know how to make the rectangle from viewport crop invisible. it seems to have same settings as other viewports. ideas? Quote Link to comment
AlanW Posted October 9, 2015 Share Posted October 9, 2015 You will probably find the rectangle you used for the crop is on a class that is still on. Place them on the none class or turn it off. HTH Quote Link to comment
POA Posted October 9, 2015 Share Posted October 9, 2015 If it is the crop border there is also a tick box in the object info palette called "crop visible" that will turn the crop border on and off. Quote Link to comment
jmartinarch Posted October 9, 2015 Author Share Posted October 9, 2015 (edited) If I turn the class of the viewport off the crop goes away and so does what was in the viewport. The tick box "crop visible" is unchecked. The viewport is in the "none" class. The line is a pale grey. On this particular sheet I have two viewports and only this one is the problem. I deleted the offending viewport and re-created. No border visible now. Edited October 9, 2015 by jmartinarch Quote Link to comment
