Steven Kenzer Posted July 17, 2015 Share Posted July 17, 2015 I was wondering if someone out there might be able to suggest to me how to create "irregular" surfaces to this table. Think reclaimed wood. Instead of a straight edge to a board, I'd like it to be slightly "wany", more natural/organic in appearance. Also, the surfaces should have more of a hand hewn/textured look to it. I believe the later is done by editing the bump of the texture in the resource browser, although not certain. I've tried creating the wany edge by using the freehand tool and then composing a rectangle. I probably could pull that off but it was quite difficult. I though there might be a quicker way, one I'm not aware of. Thanks in advance for any help on this...it's always appreciated. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 17, 2015 Vectorworks, Inc Employee Share Posted July 17, 2015 You're looking for a Displacement mapped texture, which is inside the Bump shader. http://kbase.vectorworks.net/questions/1314/Quick+Bump+and+Displacement+Mapped+Textures The video covers it very briefly, I can explain more if need be. There are a large number of displacement mapped textures of reasonable quality available for free from sites like Maxwell Render which I use regularly: http://resources.maxwellrender.com/search.php#page=1&mode=1&id=5224&search=wood&v1=0&v2=0&tipo= Quote Link to comment
Steven Kenzer Posted July 17, 2015 Author Share Posted July 17, 2015 Thanks, Jim..I'll check this out. Looks like the drawing file wasn't attached. Here it is... Quote Link to comment
Steven Kenzer Posted July 17, 2015 Author Share Posted July 17, 2015 Thank you again, Jim. This is much more in keeping with what I had in mind. Still needs some work/tweaking but......on the right path now. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 17, 2015 Vectorworks, Inc Employee Share Posted July 17, 2015 The trick is getting the right displacement height, and making sure the object is scaled realistically. Also, make sure in your rendeirng mode you have enabled displacement mapping, I dont think Final Quality includes it, but dont turn it higher than "High." Very High looks a LITTLE better but in all seriousness can increase your rendering times 10x or more. Quote Link to comment
Steven Kenzer Posted July 17, 2015 Author Share Posted July 17, 2015 Even better....what a great resource of textures, Jim. Thanks so much for pointing me in that direction. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 17, 2015 Vectorworks, Inc Employee Share Posted July 17, 2015 No problem! I use and abuse that library thoroughly. Quote Link to comment
AlanW Posted July 17, 2015 Share Posted July 17, 2015 Hi, If you are interested in creating your own displacement maps this video explains how I go about it. HTH. Quote Link to comment
Steven Kenzer Posted July 17, 2015 Author Share Posted July 17, 2015 Thanks, Alan......helpful video, for sure. Quote Link to comment
