Jim Smith Posted March 10, 2003 Share Posted March 10, 2003 I have not used VW-10 yet. Can a 3-D drawing be exported to DXF/DWG to give cutting instructions to a CAM system? Quote Link to comment
Guest Posted March 10, 2003 Share Posted March 10, 2003 VW files can be exported as dxf/dwg files in vw 10 including the surface of these objects. If you have a CAM machine that can use DXF files for this purpose, you should be able to do it. What version of VW do you have now and what type of problems are you running into when exporting and sending to a cam machine? Quote Link to comment
Jim Smith Posted March 11, 2003 Author Share Posted March 11, 2003 Using VW 8.5.2 on a Mac with G-4. I have no problem in the past with 2-D exporting DXF. I have a client who is looking at starting with an Abobe Illustrator file of a cardboard merchandiser, I would then work up a 3-D model to be exported to die cutters. Quote Link to comment
Guest Posted March 11, 2003 Share Posted March 11, 2003 VW 10 allows IGES and STL file export. Would either of these exports be compatible with the die-cutters? Unfortunately, I don't know much about CAM machines and die cutters, etc. I have a basic overview of them, but nothing too in depth. Quote Link to comment
Jim Smith Posted March 13, 2003 Author Share Posted March 13, 2003 AS FAR AS I KNOW THE CUTTERS WILL ACCEPT A DXF FILE, MY CONCERN IS WOULD I HAVE TO EDIT 2-D OBJECTS AND EXTRUDE THEM RATHER THAN USE SUBTRACT/INTERSECT SOLIDS? WITH THE 2-D EDIT OPTION, OFTEN UNWANTED LINES APPEAR. IF I EXPORT A DXF WOULD THESE UNWANTED LINES BE A PROBLEM IN THE INCOMING PROGRAMME? -ALSO, I HAVE SHOWN ANOTHER CLIENT CROWN MOLDING DESIGNS, BUT I FIND I HAVE TO USE RAYMAKER TO ILLUSTRATE EVEN A SIMPLE ISO. DRAWING AS AN EXTRUDED MOLDING IS NEXT TO IMPOSSIBLE TO UNDERSTAND AS A FINAL HIDDEN LINE DRAWING. IS THERE A MORE SIMPLE WAY TO SHOW A LINE DRAWING OF THINGS LIKE TUBES, MOLDING, STEEL WIRE ETC. IN 3-D SO THAT I DO NOT HAVE A MASS OF MENINGLESS LINES? OR DO I HAVE TO DO WHAT I DO NOW, IE. DRAW PLAN, ELEVATIONS, AND THEN RENDER AN ISO. IN RAYMAKER? MANY CLIENTS JUST WANT A LINE DRAWING AND I FIND I HAVE TO ADD LINES IN A LAYER "ABOVE" THE RENDERED ISO. VIEW. Quote Link to comment
propstuff Posted March 14, 2003 Share Posted March 14, 2003 Jim, If you look in the Plugins section of /URL] I think you'll find a script for VW8.5 called "smoothing angle" (?) By using this you can simplify the Hidden Line renderings to produce the simple outlines you want. VW10 now has this built in. Cheers, N. Quote Link to comment
Jim Smith Posted March 15, 2003 Author Share Posted March 15, 2003 Very large! Thanks, Quote Link to comment
