johncruet Posted February 14, 2003 Share Posted February 14, 2003 The glass in the simple window isn't transparent as it cuts the wall. this was not a problem in Version 8.5. What did I do wrong? Quote Link to comment
Guest Posted February 14, 2003 Share Posted February 14, 2003 The panes on doors and windows are set by class styles as of Vw 9. When you select a window or door iwth a pane in it, there is a setting in the OIP at the bottom called Class Settings. In here is a Glazing setting. There is a drop down box next to Glazing with 3 settings. Selecting one of these other than None will create the associated class. Then you will need to go to the Classes dialog box and select the Style-Glazing-# class and assign an attribute to it. By default, the setting is set to Solid White. To make it transparent, you can change the solid white to a none fill, or you can apply a glass texture. Quote Link to comment
jfmarch Posted February 15, 2003 Share Posted February 15, 2003 what I do is turn off the "style" classes while im model view. that way any glazed opening in windows or doors appear as voids.... Quote Link to comment
