JennieYeung Posted November 17, 2014 Share Posted November 17, 2014 I am using VW2015 - English version. Wrong gobo is projected and my method is, *** Start with a blank drawing with Spotlight as template. A box is drawn with “rectangle” and “extrude” A “focus point” "A" is draw on the box at 10’ high An ETC 10 degree is draw 20’ away and height at 10’ and focuses at "A" Draw beam is activated. Gobo template Apollo 2137 is imported from the VW2015 library. In the OIP if the light instrument, the gobo is chosen at the edit menu. At left isometric view, Final Quality Renderworks is chosen. The gobo projected is NOT what it is suppose to be. Quote Link to comment
michaelk Posted November 18, 2014 Share Posted November 18, 2014 I'm not seeing 2137 in the library. Can you post the file? mk Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 18, 2014 Vectorworks, Inc Employee Share Posted November 18, 2014 Also, if you could please post a screenshot of what you're getting: http://kbase.vectorworks.net/questions/892/How+to+take+a+Screen+Shot Also, are you using SP0 or SP1 of Vectorworks 2015? What operating system? Adding this information to your signature will make this easier in the future. Quote Link to comment
JennieYeung Posted November 18, 2014 Author Share Posted November 18, 2014 I am using Vectorworks 2015 SP1 (Build 237820) Window 7 Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 18, 2014 Vectorworks, Inc Employee Share Posted November 18, 2014 Where are you seeing that it is stars? Looking at the gobo and the results, they match on my end. A series of dots in a gridlike pattern. It also appears this gobo matches the real world versions: http://www.norcostco.com/rivet-wall-apollo-glass-gobo-sr-2137.aspx http://www.amazon.ca/Apollo-Rivet-Wall-Super-Resolution/dp/B003ZAGO02 Quote Link to comment
JennieYeung Posted November 18, 2014 Author Share Posted November 18, 2014 I got mine from the following link and I searched on the Gobo Texture library using "2137" http://www.norcostco.com/star-field-apollo-gobo-2137.aspx Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 18, 2014 Vectorworks, Inc Employee Share Posted November 18, 2014 Ahh thats it then, the one you're using from us is "#SR-2137" instead of "#2137". We do not have a "#2137" in our Apollo Stars library. You could create your own from that image on their website, just duplicate one of the existing gobos and replace the image source. Quote Link to comment
