minotto Posted September 22, 2014 Share Posted September 22, 2014 I have a very basic question that i can't seem to find an answer for. After extruding a rectangle with a fill and line indicated in the Attributes window, the fill disappears. When switching to the 3d form it shows up fine but when i switch back to Top Plan, only the outline of the 2d form shows. I tried alternating different Fill options but still only the outline is affected when i change the line parameters. Editing the extruded form shows the correct fill. How do i correct this? Quote Link to comment
CipesDesign Posted September 23, 2014 Share Posted September 23, 2014 Extrudes, by definition in VW's, have always behaved like this. In order to get the 2d view of an extruded form to have a solid fill use one of the following methods (there are probably more): 1) Use other "Hybrid" Objects (like Floors for example) when appropriate; 2) Use the Create Auto Hybrid command; or 3) create a 2d/3d Hybrid Symbol by using both the Extrude and a Rectangle (or any shape) drawn in Top/Plan view, and exactly aligned with the Extrude. Select both objects and then use the command Create Symbol. Quote Link to comment
minotto Posted September 23, 2014 Author Share Posted September 23, 2014 Thanks Peter. Quote Link to comment
