Cadplan Architecture Posted September 20, 2014 Share Posted September 20, 2014 VW 2015 still seems to make quite large file sizes even when the Purge command is used. Re 64bit; this has long been talked about but what difference should we be noticing when using 2015? Quote Link to comment
zoomer Posted September 20, 2014 Share Posted September 20, 2014 It can use all your RAM. 32 Bit could only use 2 (3) GB. When working with larger files you could reach that limit and got these error messages. So it should work now to f.e. export larger IFC models etc. Quote Link to comment
