yasin2ray Posted June 13, 2014 Share Posted June 13, 2014 I am working on a residential design project, and I need to bring in the AutoCAD file that contains the survey and architectural linework. The AutoCAD file has unit settings of "Decimal" and "Feet". I have brought it in as a Reference File. When I brought it in I said the units were Feet. I can see the file just fine. But it is displaying in Inches, not Feet. For example, the 10' wide driveway measures 10" wide. When I scale the Referenced File (by 12), I cannot see the linework anymore! I can find the crop boundary and select it, so I know it's still there. But what's up with the file contents? Is my process correct but incomplete? Or am I doing this all wrong? Thanks for your help! Anna Quote Link to comment
Benson Shaw Posted June 13, 2014 Share Posted June 13, 2014 Did it expand beyond the crop so vp displays an empty area between the linework? Edit the crop to see if the objects are out side the crop boundary. -B Quote Link to comment
yasin2ray Posted June 16, 2014 Author Share Posted June 16, 2014 This helps in part - I expanded the crop boundary and found the linework. However, the linework has not changed size. It has only moved location! Oddly, every time I try to Scale Objects (using either the symmetric option or the Symmetric By Distance option), the linework actually moves 'north' but does not change size... Any ideas about that? anna Quote Link to comment
yasin2ray Posted June 16, 2014 Author Share Posted June 16, 2014 I seem to have fixed it. Perhaps just a computer glich? Just to see how it would go, I made an AutoCAD file in Architectural-Inches and brought that in - no problems. The size was correct. Then I brought in the Decimal-Feet file again and, mysteriously, it is now working fine. It's the right size/scale. Somewhere in there, I also shut down and restarted my computer. Hmm. Quote Link to comment
