Design layer's class and layer visibility settings should be saveable on a layer by layer basis. i.e. a saveable layer/class template applicable to each design layer.
For example:
Your roof plan shows different info to your floor plans and landscape plans. If I want to make changes to the roof but the last plan I worked on was the landscape plan, then I have to tango with the class/layer visibilities to get the required info to show. So I'm happy now with the roof and I want to work on the landscape plan again. I then have to undo everything I've done with my visibility settings.
VW has a workflow structure that requires too much time to maintain i.e. Layers, Classes, Saved Views, Viewport Overides.
How about incorporating Saved View funtionality into the design layer itself and to be able to save, edit and apply different combination of settings as a pre-set to the design layer, which you can then apply to future design layers etc. Should work for all disciplines.
Kizza
For example:
Edited by KizzaLink to comment
5 answers to this question
