#1 ? And most important: The reshape tool still has the fillet radius entry field hidden away in a submenu. Please place it directly on the data bar.
#2 The push/pull extrude face ? used on a solid object ? creates a tapered extrude and adds it to the solid, that it is used upon. This is actually a really useful feature. But when the tool is used on a 2D surface, I get an ordinary extrude, which is really just less. I want tapered extrudes everywhere and I want a taper angle entry field on the push/pull databar.
#3 Actually: Please kill the basic extruded object altogether and display a taper setting for any extrude on the OIP.
#4 The rotate setting on the OIP for extrude-along-path objects rotates the entire object. I can do that myself. I want the rotate-setting to rotate the profile within the extrude-along-path object and I want an additional setting to control how much that profile is twisted/rotated along the path.
#5 When I drag n' drop an image onto an open VW document, I want a dialogue, that provides me with a complete set of options as to how to use the imported image. With a single click, I want to be able to use the dropped image as an image, a texture, an image prop, an image fill or as a Renderworks background.
#6 Wall settings should include options for wall bases and edgings (I am not familiar with the correct terms in english). These could be texture based or consist of actual 3D geometry.
#7 Kill the Add Decal command or redesign it. It is useless in its present state.
#8 The physical skies are all blue or blueish. I wish I could change the hue and saturation
#9 Rotating image environments is a pain. In fact it is a royal pain. I often have to make several versions of the same image environment because tweaking it is so time consuming. I wish the visualization palette had a tab for renderworks backgrounds, that included a fast, intuitive tool for tweaking image environments.
#10 I wish for more tools like the Twist Tool: A Bend Tool, a Bulge Tool, a Taper Tool, a Distort Tool, etc.
Kaare Baekgaard
Top 10 wishes for the next versions of VW:
Thanks for listening.
Edited by Kaare BaekgaardLink to comment
7 answers to this question
