Phil hunt Posted October 6, 2013 Share Posted October 6, 2013 I have created a shape 3000mm x 1000mm 100 mm thick with rounded corners this shows up in wireframe correctly but when rendered in final quality renderworks the shape turns to sq corners.....has anyone experienced this problem Quote Link to comment
Phil hunt Posted October 6, 2013 Author Share Posted October 6, 2013 I am also having problems with applying decals in 2014 I have applied a decal and tried to take a white background just to reveal the black lettering with great problems however the same usage in 2013 works every time with no problem..... Quote Link to comment
Bruce Kieffer Posted October 7, 2013 Share Posted October 7, 2013 Phil, Give us the steps you used to create the shapes. Also, it is best to make separate posts for different questions you have, and add your system info to your profile so we know better how to help you. Quote Link to comment
Phil hunt Posted October 7, 2013 Author Share Posted October 7, 2013 hi bruce first time post so sorry about the 2 questions so created a rectangle 3000mm x 1000mm and then applied a rounded corner fillet of 250mm dia and then extruded to 150mm thick applied a decal and then rendered, although in wireframe you could see the corners when rendered they appear sq as the original rectangle of 3000 x 1000, as i could not work why this was happening i did the same command again to create the shape applied the decal and saved it as a symbol....this solved the problem on the original i also converted the shape to 3d polys and that worked but of course i lost the decal this is strange i have been using VW for 12 years but use artlantis as my render package, so i am on a steep learning kerb as i want to use renderworks as my main render package, the results are far superior. many thanks Quote Link to comment
Bruce Kieffer Posted October 7, 2013 Share Posted October 7, 2013 No worries Phil, we want to help as much as we can. It sounds like you got it working. I cannot recreate the problem here, but I can say that I see no reason why you had the problem. Was the file converted from an older version of Vectorworks? Did you try creating the same shape in a new blank document? That would eliminate file corruption as the culprit. Next trouble shooting steps after that are reboot Vectorworks, if no change then restart your computer, no change, then test on another computer, no change then contact tech support and send them your file. Posting your file here for other users to inspect is an option too. I'm confident you'll have luck learning Renderworks faster than you think. There are some good tutorials out there. The book Remarkable Renderworks is one. Quote Link to comment
Phil hunt Posted October 7, 2013 Author Share Posted October 7, 2013 thanks bruce no it was 2014 and i just can't work this one out but i will try it again when i start a new job.....many thanks i will certainly try the book you recommend...... Quote Link to comment
