Patrick Fritsch Posted October 4, 2013 Share Posted October 4, 2013 For you Jim W! When you create a custom window, with let's say 2 rows and 2 columns of sash's, then if you lock one of those and re-size the "overall" width or height, the locked window does not re-size. You have to go in and unlock it and then do the overall re-size if not you'll have to start your custom window all over as the dims get all messed up for each sash. Now this anomaly makes me think of a cool feature, is you could create L-shaped window configurations as one unit, if the frame could be adjusted to the locked sash panes. Check the attached file. Quote Link to comment
Kizza Posted October 4, 2013 Share Posted October 4, 2013 Is this the behaviour you are experiencing? Link Quote Link to comment
Patrick Fritsch Posted October 5, 2013 Author Share Posted October 5, 2013 No not the same problem Kizza. Check out the VWX file attached. Quote Link to comment
Kizza Posted October 5, 2013 Share Posted October 5, 2013 I have VW2012. Sounds like a good idea, would also need to be able to delete a sash as well to create an L shaped window no? Quote Link to comment
Patrick Fritsch Posted October 10, 2013 Author Share Posted October 10, 2013 Jim, have you had a chance to check out this bug? Thanks, Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 10, 2013 Vectorworks, Inc Employee Share Posted October 10, 2013 For the locking, that is how it should function. If a sash is locked, then you would not want it to change regardless of any other changes you made to the window. If it changed size when locked, what would be the reason for locking it? (Unless I am misunderstanding your explanation.) As for the custom window enhancement, I agree, there was another user who saw multiple hexagonal/diamond windows combined into a more advanced window shape that they wanted to see as a custom window shape, so that it could all be included as one window for the schedule. I'll write up a submission shortly. Quote Link to comment
