Kizza Posted August 31, 2013 Share Posted August 31, 2013 I want to create a simple drawing list linked to my title block. Create sheet list won't work because my titleblock is not a VW default. (who's bright idea was that?) This takes 10 seconds to do in Revit. I've spent 2 hours trying to figure it out. I guess the solution is to create a worksheet linked to the title block? Is there any tutorials out there to step through how to create a simple drawing list? Quote Link to comment
grant_PD Posted August 31, 2013 Share Posted August 31, 2013 If your title block has text linked to records ( I assume it does) then, "create report" Scroll down the list of symbols that have a record till you find your title block move over the fields you want to list and press OK. Quote Link to comment
Kizza Posted August 31, 2013 Author Share Posted August 31, 2013 (edited) That worked and took 6 seconds Here I am trying to create the worksheet manually using the paste criteria function and using another user's worksheet as a template and the automatic solution was in my face! Thanks. Edited August 31, 2013 by Kizza Quote Link to comment
grant_PD Posted August 31, 2013 Share Posted August 31, 2013 save that worksheet, and put it in your resources. Then when you start a new project, you can just import it and update. Quote Link to comment
