ChadL Posted May 20, 2013 Share Posted May 20, 2013 I recently read a post about changing the Lighting Device Parameters, and re ordering. This is one of the greatest tricks I have learned about VW lately. I always have to scroll down in my OIP to get to the part I want. The only problem I am running into it is that it does not save the settings. Even if I select 'set as default' when I open a new document it goes back to default. Is there a way to save these preferences so every document I open (even old ones) gets the same OIP settings for lighting devices? Thanks, Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 20, 2013 Vectorworks, Inc Employee Share Posted May 20, 2013 At the top of the dialog where you setup the parameters there is a place to save the settings. When you open a new document it will default to the last saved settings. In existing documents you have to manually recall the saved set. Quote Link to comment
