marshigh Posted February 8, 2013 Share Posted February 8, 2013 I would like to add a new column to my door schedule that lists which floor (of the structure) the door/window can be found. What would be the database formula for this new column? Thank you! Mark Quote Link to comment
michaelk Posted February 8, 2013 Share Posted February 8, 2013 If your Layer name for the floor is descriptive and not cryptic you could use that. The call to get the database to return the layer name is =L hth mk Quote Link to comment
marshigh Posted February 8, 2013 Author Share Posted February 8, 2013 So easy!! Thank you. I have (almost) zero experience with spreadsheets. Do you know of any good resources for basic stuff like this? thx again. Quote Link to comment
marshigh Posted February 8, 2013 Author Share Posted February 8, 2013 Same issue, two new items: Window schedule.... in the column marked "muntins" each line says "colonial" even though none of my windows have muntins checked. Is this a bug? Is there a work around? under egress: The default for all the data is "False" (I understand that I would have to mark them manually)...but is there any way to do a computation for the window that would "true" if over 5.7 sq.ft.? Thank you! Quote Link to comment
michaelk Posted February 9, 2013 Share Posted February 9, 2013 I always look at the default schedules as a guide and I adapt them as necessary for my project. If you don't need the muntins column, then delete it. To get the egress window true/false, it's just an IF/THEN statement. Try this: =IF(('Window'.'OverallWidth')*('Window'.'OverallHeight')<=5.7, 'FALSE', 'TRUE') hth mk Quote Link to comment
genie Posted September 19, 2013 Share Posted September 19, 2013 I'm trying to show the single width and height of similar doors in my door schedule when I sum door type column together. I added a new column in my door schedule and use "=count" and revised the door width formula to"=(Door.Width)/Q4" (Q4 being the cell number of "=COUNT"). It doesn't seem to be working. The door width column is still showing the total widths of the same type of doors. Am I doing something wrong? Thank You! Quote Link to comment
michaelk Posted September 19, 2013 Share Posted September 19, 2013 genie This is a little counter intuitive, but this is how it works. 1. Select a database row header (x.xx) 2. Drag the SUM badge into the column you want to summarize. (Just as you did with the door type) 3. Select a database row header again. 4. Drag the SUM badge to the column you DON'T want to summarize. Like the width column. Repeat for all other columns you don't want to summarize. In the event that there are doors of the same type with different widths (not likely) the cell will display a dash to indicate returned values that are not identical. hth mk Quote Link to comment
michaelk Posted September 19, 2013 Share Posted September 19, 2013 PS I don't know why =(Door.Width)/COUNT or =(Door.Width)/Q4 doesn't work. I think your instincts were right. In general, that sort of thing works. mk Quote Link to comment
