G. Pfrommer Posted January 19, 2013 Share Posted January 19, 2013 Greetings, I'm using Design 2013 with Jan 18 SP update I have created truss and converted it to a lighting position. I keep truss and lights on separate layers for plotting purposes. When I try to insert a lighting fixture on the same class as the truss it works fine. If I change class to other than the truss class and insert the fixture it will snap to the object but when I place it is appears below 0' and does not hang on the truss. The only way that will work inserting a fixture on a truss on a different class if I have the "Show/Snap/Modify other" turn on in the classes options . Why cant I do the same thing with the "Show/Snap" option Quote Link to comment
CipesDesign Posted January 19, 2013 Share Posted January 19, 2013 Two things to keep in mind: 1) You should have Class settings Show Snap Modify others. 2) Layers in VW's are not the same as layers in other programs, and are not the same as Classes in VW's... Quote Link to comment
